Metro Manual
Help Contents | Help Index
Getting Started
- Getting Started
- The Basics
- Introduction
- Quick Setup
- Glossary
- Tasks
- Recording
- Audio Recording
- Editing
- Effects
- Effects Tutorial
- Adding Real-time Effects to One Track
- Adding Real-time Effects to Multiple Tracks
- Recording Auxiliary Fader Movements
- Drawing Aux Fader Movements in the Graphic Editor Window
- Applying Effects Offline
- Notation
- Reference
- Troubleshooting
Introduction
- Detailed Setup
- Opening METRO
- MIDI Setup Without OMS
- Setting Up MIDI Time Code
- Selecting Record Criteria
- Setting Record and Play Preferences
- Countoff
- NoCountOff
- Wait for the first note before recording
- Song Building Mode
- Multiple Take Mode
- "N" Tracks Maximum
Tutorials
Your First Session with Metro
- Your First Session with METRO
- Downloading OMS
- Opening METRO and Setting Up MIDI (with OMS)
- Configuring Your Audio Setup
- Creating New Outputs
- Setting Up the Metronome
- Using MIDI Thru
- Customizing METRO's Window Layout
- Saving Preferences
- Creating a New METRO File
- Importing an Audio File
- Looping a Track
- Recording Your First MIDI Track.
- Editing Your First MIDI Track
- Recording a MIDI Bass line
- Recording Another Track
Getting Deeper
- Getting Deeper
- Customizing Program Names
- Drum Machine Style Recording
- Creating a Section
- Drum Grid Recording
- Drum Grid Editing
- Adding Tracks within the Graphic Editor Window
- Plugging In and Testing a Microphone
- Setting Up Audio Outputs
- Your First Audio Recording
- Latency and the Sound Manager
- Changing Audio Volume
- Adding Effects in Real-time
- Adding Offline Effects
- Arranging with Subsections
MIDI Recording
- MIDI Recording Tutorial
- Setting a Port to the Record Track
- Enabling the Metronome Click
- Setting the Record Mode: Replace or Overdub
- Beginning Recording
- Naming Your Track
- Viewing Note Data
- Playing Back the Track
- Playing From a Selection or Bar Number
- Adjusting Note Velocity
- Saving Your Recording as a METRO File
- Enlarging the Transport Window
- Playing and Setting Cues
- Looping Playback of Your Track
- Looping Playback of an Area Within Your Track
- Looping Cues
- Auditioning Programs
- Adjusting Current Playback Tempo
- Displaying Multiple Tracks in the Graphic Editor Window
- Selecting Tracks in the Graphic Editor Window
- Naming the Current Section
- On-The-Fly Recording
Basic MIDI Editing
- Selecting Notes, Tracks and Sections for Editing
- Selecting Data in the Graphic Editor Window
- Edit Notes in Selection Only Option
- Choosing a Zoom Level in the Graphic Editor window
- Selecting Noncontiguous Notes or Areas in the Graphic Editor Window
- Selecting Notes Defined by Particular Criteria (Selection Filter)
- Editing Notes in the Graphic Editor Window
- Repeatedly Pasting Notes
- Selecting Tracks or Track Regions in the Tracks Window Overview
- Choosing a zoom level
- Choosing a select quantize resolution
- Selecting Tracks
- Types of Data Display in the Tracks Window Overview
- Selecting Sections
Advanced MIDI editing
- Editing MIDI Events
- Inserting Program Events (Changes) into a Track
- Recording Program Change Events
- Recording Controller Events
- Controlling Tempo
- Entering Tempo Events in the Tempo Dialog Box
- Entering and Editing Tempo Events in the Section Event Editor Window
- Recording Tempo Events
- Recording Tempo Changes from Your Controller
Using Outputs, Ports, and Faders
- Using Outputs, Ports, and Faders
- Using Metro Outputs
- Ports
- Creating Outputs with OMS
- METRO Outputs without OMS
- Naming Outputs
- Setting Output Channels
- Auditioning Programs from the Instruments Mixer Window
- Adding Outputs/Faders
- Deleting Outputs/Faders
- Faders
- Assigning Pan or Volume Faders to Shape Controller Data
- Assigning SysEx to Output Faders
- Recording Controller Events Using Faders
- Viewing Controller Events
- Recording One Controller Event
- Recording Data on Multiple Faders
- Grouping Faders
- Moving All of the Faders at Once
- The Master Fader
- Saving Faders and Output Setups
- Opening Old METRO Document Files
Advanced MIDI Recording
- Advanced MIDI Recording
- Tap Tempo
- Recording System Exclusive Events
- Punch Recording
- Loop Recording
- Using Song Building Mode in Replace
- Using Song Building Mode in Overdub
- Recording in Multiple Take Mode
- Step Recording
- Step Recording from a MIDI Device
- Step Recording with the Pencil Tool
Working with SubSections
- Working with SubSections
- Creating SubSections
- Editing SubSection Start Time and Duration
- Duplicating SubSections
- Cloning SubSections
- Copying SubSection Tempo, Key Signature, and Time Signature Events
- Editing Tracks in SubSections
- Expanding by SubSections
- Deleting SubSections
Menus
- Metro Menu Commands
- The File Menu
- New
- Open
- Import Movie
- Close Movie
- Close Window
- Save
- Save As
- Save As Portable Bundle
- Revert
- Import Audio File
- Export Audio Track to File
- Mix Audio Tracks to File
- Export As Movie
- Import MIDI File
- Importing MIDI files
- Export MIDI File
- Saving in Standard MIDI Format
- Insert SysEx Data
- Links
- Preferences
- General Preferences Pane
- Timing Preferences Pane
- Buffers Preferences Pane
- Movie Preferences Pane
- Jukebox Preferences Pane
- Thru Settings
- Interpret Overlapped Notes As
- Middle C Is
- Note Colors
- SysEx Buffer Size
- Digital Audio Playback Buffer Size
- Digital Audio Record Buffer Size
- Page Setup
- Print
- Quit
- The Edit Menu
- Undo
- Redo
- Cut
- Copy
- Paste
- Pasting a Section
- Clear
- Delete Tracks
- Archiving Tracks
- Multitrack Audio Recording
- Audio
- Normalize
- Group Normalize
- Reverse
- Scale Amplitude
- Fade
- Cross-Fade
- Split Stereo Tracks
- Combine Regions
- Paste And
- Expand
- Expand by Channel
- Expand by SubSections
- Expand by Loops
- Expand by Drums
- Get Section Events
- Merge Data
- Merge Tracks to New
- Extract Data
- Delete Duplicates
- Delete Time
- Insert Time
- Select All
- Set Selection
- The Options Menu
- Quantize
- Attacks and/or Releases
- Quantize To
- Recognize Triplets
- Groove Named
- Track
- Groove Velocity and/or Duration
- Strength
- Swing
- Duration
- Set Values To
- Scale to
- Add "N" Clocks
- Extend Durations to Next Note
- Concatenate Notes
- Transpose
- In the Scale Of
- From the Scale Of
- Set All Notes To
- Using Map
- Human Feel
- Randomize Start Times
- Randomize Durations by
- Randomize Velocities by
- Insert Random Tempo Changes with
- Harmony
- Velocity
- Attack or Release Velocities
- Set To
- Add
- Scale to "N"%
- Change Gradually From "N" to "N"
- Change Gradually From "N%" to "N%"
- Change All Selected Notes To
- Channel
- Reverse
- Shift Events
- Continuous Data
- Audio Automation
- Pitch Bend
- Scale Time
- Scale Tempos To Preserve Time
- Limit
- Thin Continuous
- Tempo
- Set Tempos to "N" beats per minute-
- Set Tempos to change gradually from
- Scale Tempo so selection fits to
- Scale Tempo so selection ends at
- Time and Key Signatures
- MIDI Messages
- GM System On
- GS Reset
- XG System On
- All Notes Off
- All Sound Off
- Local Control Off/On
- Reset All Controllers
- Omni Mode Off
- Omni Mode On
- Mono Mode
- Poly Mode
- The Windows Menu
- Ignore Positions
- Reset
- The Switches Menu
- Bar Display/SMPTE Display
- Selection Filter
- Playback Scrolling
- SysEx in Graphic Editor
- Velocity Stems
- Pitch Bend Display
- Scrubbing
- Double Click to Event Editor
- Partial Track Recording
- Automatic MIDI Thru
- Constrain Note Dragging
- Audio Region Editing
- Show Audio Regions
- Zero Crossing
- Note Edit Quantizing Mode
- Connect to DECK
- The Special Menu
- Looping Options
- Clear Selected Loops
- Modify Outputs and Busses
- Output Groupings
- Restore Outputs
- Chord Entry Method
- Chord Type
- Enter Chord Mode
- Real-time Arpeggiator
- Restore Cue
- Set Cue
- Zoom In
- Zoom Out
- Program Names to Tracks
- Setup Notation Track
- The Setup Menu
- Record Criteria
- Record/Play
- Note Edit Grids
- Color Scheme
- Font, Size and Style
- Selection Filter
- Velocity
- Random Selections
- Assign a Rhythm Pattern
- Groove Quantize
- Add Selection as Groove
- Paste Groove
- Remove Groove
- Chasing
- Scales/Chords
- Tap Tempo
- MIDI Monitor
- Change Ports
- Program Names
- Extract Program Names
- Program Name List
- Edit Program Name List
- Open Program Name List
- Clear Program Name List
- Clear All Program Name Lists
- Saving Program Name Lists
- Subscribing to Universal Editor/Librarians
- Sort by Names in Pop-ups
- Sending Bank Select Messages
- Drum Set Editor
- Select Drum Set
- Save Set As
- Import Set
- Export Set
- Delete Selected Set
- Add User Drum
- Drum Assignment Display
- Favorite Controllers
- Nudging
- Digital Audio Setup
- For Metro Digital Audio
- Digital Audio Dialog Options: Direct Support
- Digital Audio Dialog Options: ASIO
- Digital Audio Dialog Options: Sample Rate
- Digital Audio Dialog Options: Bits
- Digital Audio Dialog Options: Stereo
- Digital Audio Dialog Options: Device Options (formerly Recording Options)
- Digital Audio Dialog Options: Advanced
- Digital Audio Dialog Options: Switch Without Stopping MIDI
- For Connecting to Deck II
- Digital Audio Dialog Options: Connect
- Digital Audio Dialog Options: Open Documents
- Digital Audio Dialog Options: Launch
- Digital Audio Dialog Options: Quit
- MIDI Machine Control
- Time Code
- MIDI Setup
- OMS MIDI Setup
- OMS
- OMS Studio Setup
- OMS Setup
Windows
- Memory
- The Sections Window
- Working in the Sections Window
- Naming a section
- Song Playlist
- Section Timing Options
- The Tracks Window
- Selecting and Moving Tracks
- Setting Track Status in the Track Window
- Naming Tracks in the Track Window
- Looping in the Track Window
- The Bars Column
- Assigning Outputs in the Track Window
- Ports and Outputs
- Changing a Port in the Track Window
- Viewing Track Levels in the Track Window
- SubSection Pop-up Menu
- Tracks Window Overview
- Zooming In and Out in the Tracks Overview
- Setting Selection Quantize Amount in Tracks Overview
- Selecting All Tracks in the Tracks Overview
- Ranging Selection Across All Tracks in the Tracks Overview
- Entering Markers and Chord Symbols in the Tracks Overview
- Playback Options in the Track Window
- Playback Quantize
- Playback Transpose
- Playback Velocity
- The Graphic Editor Window
- The Track Titlebar
- MIDI Track Display Modes
- Configuring the Graphic Editor Window
- Notes Display - MIDI Piano Roll
- Audio Display - Audio Regions
- Working with Audio Tracks and Audio Regions
- Drums Display
- Drums Display Selection Tools
- Working with Drum Sets
- Creating and Naming a New Drum Set
- Transposing from Drum Set to Drum Set
- Transposing from Drum Name to Drum Name
- Selecting All Note Data Across a Single Drum Name
- Showing All Drum Names within a Drum Set
- Rearranging the Order of Displayed Drum Names
- Adding a New Drum
- Nudging the Start Time of Drum Strikes
- Muting and Soloing Drum Names
- Scaling Velocities of Selected Drum Strikes
- Changing Drum Strike Velocity Ranges
- The Continuous Data Display Modes
- Arrow
- Pencil
- Curve Tools
- The Pitch Bend Display
- Viewing Pitch Bend Events in the Notes Display
- Setting the Pitch Bend Range
- Editing Pitch Bend Events
- The Controller Display
- Average Velocity
- The After Touch Display
- The Poly After Touch Display
- The Program Change Display
- The Tempo Display
- Display Multiple Tracks
- Zoom In and Out
- Audible Keyboard
- Markers/Chord Changes
- Name and Set Marker Location
- Name and Place Chord Change
- Edit Markers
- Lock Markers or Chord Changes
- Delete Markers and Chord Changes
- Current Cursor Position
- Arrow Tool
- Pencil Tool
- Forceps Tool
- Velocity Stem Edit Tool
- Horizontal Keyboard
- Scale Tool
- Spray Paint Tool
- Tips for using Note Spray
- Channel
- Rest, Note Value, Velocity, % of Value
- Program
- Bank
- The Event Editor Window
- ChangingTracks
- Event Information
- Selecting Events in the Event Editor Window
- Selecting Multiple Events in the Event Editor Window
- Setting Event Start Time in the Event Editor Window
- Go To a Specific Bar in the Event Editor Window
- Selecting and Editing Event Parameters
- Inserting Events
- Placing Events at Precise Locations
- Filtering Event Display
- Event Types
- Note Events
- Poly After Touch
- Controller Events
- Program Events
- After Touch
- Pitch Bend
- SysEx
- Bank Select
- The Section Event Editor
- Initial Tempo, Key Signature, and Time Signature Events
- Selecting Events in the Section Event Editor Window
- Selecting Multiple Events in the Section Event Editor Window
- Setting Event Start Time in the Section Event Editor Window
- Inserting Section Events
- Placing Events at Precise Locations in the Sections Event Editor Window
- The Instruments Mixer Window
- Setting a Port in the Instruments Mixer Window
- Setting a Channel in the Instruments Mixer Window
- Selecting a Bank Select Message in the Instrument Mixer Window
- Setting a Program Number in the Mixer Window
- Setting a Pan Value in the Instruments Mixer Window
- Setting a Data Field Value in the Instruments Mixer Window
- Output Name
- Faders
- Muting and Soloing Outputs in the Instruments Mixer Window
- Master Fader
- Snapshot Button
- The Markers Window
- Creating a New Marker
- Shifting Markers
- Select All Locked Markers
- The Transport Window
- The Remote Control Window
- Record Loop
- Rhythm Explorer
- All and None Buttons
- Rhythm Explorer Algorithms
- Using the Rhythm Explorer
- Note Pad
- QuickTime Window
- QuickTime 3.0
- Plug-ins Window
- Effects Window
- Dry
- Send
- Return
- Bypass
- Name
- Preset Menu
- Effect Parameters
- Metro's Effects
- Reverb
- Stereo Reverb
- Delay
- Stereo Delay
- Stereo Chorus
- Stereo Flange
- Tremolo
- Stereo Parametric EQ
- Mono Parametric EQ
Notation
- Using Notation
- Notation Overview
- The Notation Window
- Using the Notation Window
- Adjusting staff spacing in a single system
- Adjusting staff spacing of all systems on a page
- Adjusting staff spacing of all systems in a score
- Adding Measures to a Track
- Using the Setup Notation Track Dialog Box
- Opening the Setup Notation Track dialog box
- Features of the Setup Notation Track dialog box
- Adding or changing the track name
- Adding or changing the abbreviated name:
- Showing/hiding the name or abbreviation
- Setting the staff display options
- Changing the scale of the staff
- Assigning an instrument to the staff
- Selecting the clef for a staff
- Selecting an instrument range
- Defining a drum map for a percussion instrument
- Showing/hiding a track
- The Notation Toolbar
- Selection tool
- Selecting individual notation symbols
- Selecting multiple symbols
- Selecting contiguous symbols
- Selecting non-contiguous symbols
- Selecting all symbols in a measure
- Selecting all symbols on an entire staff line
- Selecting symbols on different staves (lasso selection)
- Selecting all symbols in a track
- Changing the pitch of notes
- Copying notes by option-dragging
- Moving symbols other than notes
- Copying symbols other than notes
- Editing symbols in the score
- Eraser tool
- Notes Tool
- Selecting from the Notes palette using the mouse
- Selecting from the Notes palette using the keyboard
- Entering notes
- Rules for note entry
- Entering rests
- Entering accidentals
- Dynamics Tool
- Entering absolute dynamics
- Entering dynamics across each staff a system:
- Editing dynamic markings
- Repositioning dynamic markings
- Copying dynamic markings
- Entering crescendo and decrescendo markings (hairpins)
- Editing a hairpin
- Text Tool
- Entering page text
- Editing page text
- Entering rehearsal text
- Editing rehearsal text
- Repositioning page and rehearsal text
- Selecting font/size/style for text
- Expressions Tool
- Adding an expression to the score
- Changing the length of expressions
- Repositioning expressions
- Editing an expression
- Barlines Tool
- Inserting dotted bar lines
- Changing bar lines
- Inserting single or double measure repeats
- Inserting first and second endings
- Transcription Quantize amount
- The Score
- Key Signatures
- Time Signatures
- Initial tempo
- Displaying/hiding tracks in the score
- Ties and triplets
- Voices
- Cursors in the score window
- The View Controls
- View options
- Voice selection
- Track selection
- Bar selection
- Page selection
- Page selection (arrows)
- Scroll bars
- Menu Commands
- Page setup
- Print
- Lyrics window
- The Button Bar
- The Lyric List
- The Lyric Editing Area
- Using the Lyric Window
- Adding the first lyric
- Applying a lyric
- Adding more lyrics
- Adding Additional Verses
- Changing the text properties of lyrics
- Changing lyrics
- Moving lyrics
- Deleting lyrics
Glossary
- ASIO
- arm/record-enable
- amplitude
- audio port
- audio region
- Audio Interchange File Format (AIFF)
- aux bus
- channel
- channel data
- chasing
- clipping
- controller data
- count off
- cue looping
- cross-fade
- digital audio
- distortion
- drum grid
- dry mix
- duration
- effects
- exponential curve
- fade
- fader
- gain
- General MIDI
- groove quantize
- instrument
- key signature
- linear recording
- Looping
- markers
- master fader
- meters
- Metro document
- Metro output
- metronome
- MIDI
- MIDI controller
- MIDI event
- MIDI sequencer
- MIDI Time Code
- mixing
- mute
- normalize
- Open Music System (OMS)
- output signal
- overdub
- .OVV
- pan
- partial track recording
- piano roll
- pitch
- playthrough
- port
- portable bundle
- preferences
- program
- program bank
- program name
- punch-in recording
- quantize
- QuickTime
- real-time
- recording
- replace
- section
- Session
- slider
- SMPTE
- solo
- Standard MIDI Files (SMF)
- step recording
- subsection
- System Exclusive Data (SysEx)
- tempo
- time signature
- track
- velocity
- waveform
- wet mix
OMS Overview
- OMS Overview
- OMS Updates METRO About Your Setup
- OMS Associates Information with Device Names
- Outputs Under OMS
- Update Outputs Under OMS
Synchronization
- Introduction to Synchronization
- Internal Sync
- External Sync
- Clock Sync
- MIDI Time Code (MTC)
- Audio Clock
- Syncing METRO to DECK II on a single Macintosh
- Syncing to Tape (FSK to MIDI Clock)
Frequently Asked Questions
- Frequently Asked Questions
- When I import a MIDI file, what happens?
- How do I record over existing music in a track (replace not overdub)?
- Why won't the Rhythm Explorer loop my music?
- How do I rename a track?
- Metro seems to erase my whole track when I record...how can I change this?
- How do I save the settings (metronome, count-off, colors, etc.) for my current project as the default?
- I get no sound from my MIDI track
- I get no sound from my audio track
