Features of the Setup Notation Track dialog box
In the
dialog box, you can do the following in the current staff:
add or change the track name
add or edit the abbreviated name
show or hide the name and abbreviation for that track
set the staff display options
change the scale of the staff
select the instrument that the staff represents
select the clef for the staff
select a range for the instrument notated on the track
define a drum-map for a percussion instrument
show/hide a track in the score
Adjusting staff spacing in a single system
Adjusting staff spacing of all systems in a score
Adjusting staff spacing of all systems on a page
Adding Measures to a Track
Using the Setup Notation Track Dialog Box
Opening the Setup Notation Track dialog box
Adding or changing the track name
Adding or changing the abbreviated name:
Showing/hiding the name or abbreviation
Setting the staff display options
Changing the scale of the staff
Assigning an instrument to the staff
Selecting the clef for a staff
Selecting an instrument range
Defining a drum map for a percussion instrument
Showing/hiding a track
