Selecting an instrument range
When you select an instrument name from the Instruments pop-up menu the LowNote and High Note fields update to show the standard note range for thatinstrument. This is for reference purposes only. If you wish to change thereference, you can customize the range by typing in new values. The left number setsthe lowest note in the range and the right number sets the highest note.
Adjusting staff spacing in a single system
Adjusting staff spacing of all systems in a score
Adjusting staff spacing of all systems on a page
Adding Measures to a Track
Using the Setup Notation Track Dialog Box
Opening the Setup Notation Track dialog box
Features of the Setup Notation Track dialog box
Adding or changing the track name
Adding or changing the abbreviated name:
Showing/hiding the name or abbreviation
Setting the staff display options
Changing the scale of the staff
Assigning an instrument to the staff
Selecting the clef for a staff
Defining a drum map for a percussion instrument
Showing/hiding a track
