Adding or changing the abbreviated name:To make staves more easily identifiable in the score, you can give each trackan abbreviated name. This displays to the left of every staff (if you checkthe Show Abbreviation box). Add or change an abbreviation by doing the following:
Click the Abbr.field.
Type in the abbreviated name of the track. If you check the Show Abbreviationbox, the abbreviated name appears to the left of all staves after the firststaff.
