Transposing from Drum Set to Drum Set
Transposing note data between Drum Set formats can be easily performed as longas more than one Drum Set has been defined within the Metro program. Beforetransposing a Drum track, you must be sure that the Drum track is assigned to thesame Drum Set that was originally used to create it. Then,
Option
-click and hold the mouse on the Drum Set pop-up menu, and choose a new DrumSet from the list of available names; all note data within the current Drumtrack will be transposed to the newly selected Drum Set. Please note that anyuser-defined Drums Names contained within a Drum Set will not be transposed; Metrocan only transpose Standard Drum Names.
Creating and Naming a New Drum Set
Transposing from Drum Name to Drum Name
Selecting All Note Data Across a Single Drum Name
Showing All Drum Names within a Drum Set
Rearranging the Order of Displayed Drum Names
Adding a New Drum
Nudging the Start Time of Drum Strikes
Muting and Soloing Drum Names
Scaling Velocities of Selected Drum Strikes
Changing Drum Strike Velocity Ranges
