Creating and Naming a New Drum Set
In the Grapfic Editor window, make sure the data display is set to drumnotes, You can change the display by clicking the track titlebar where it lists thetype of data being displayed and choosing Drums from the pop-up menu. The drumset pop-up menu is in the far left of the Graphic Editor window and is labeledeither Default Drums or with the name of a specific drum set. Click and holdthe mouse on the Drum Set pop-up menu and choose New Set... in order to create a new Drum Set from scratch. A dialog box will appearasking you to enter the name of the new Drum Set; enter the name and click OK. The new Drum Set will now be accessible under the Drum Set pop-up menu.
Metro defaults to displaying only Drum Names that correspond to MIDI noteevents within a given Drum track. Therefore, no Drum Names will be displayed in theDrum Grid if there is no MIDI note data within a track. If a Drum trackcontains MIDI note data, Drum Names that have not been defined within the active DrumSet will appear listed as Unknown.
Option-click and hold the mouse on an 'Unknown' Drum Name to assign it a new name from the list of available Drum Names within the Drum Name pop-up menu. Choose Add New Drum (near the end of the list) if you want to enter a customized Drum Name, or to add a new Drum Name from Metro's list of Standard Drum Names; the new Drum Name will be added and saved to the current Drum Set.
If your Drum track contains no MIDI note data, you can build a new Drum Setdrum by drum. Click and hold the mouse on New Drum and choose Add New Drum from the pop-up menu; select a Drum Name from the Assign to standard drum pop-up menu, or type a new Drum Name in the Add new drum to set and name it field. Enter the MIDI note corresponding to the newly entered Drum Name inthe For pitch field.
exclaim2.gifImportant: When transposing from Drum Set to Drum Set, user-defined Drum Names will notbe affected by the transposition process.
You can also display all the Drums within the currently selected Drum Set bychoosing Add All Drums from the Drum Name pop-up menu. All Drum Names from the current Drum Set willbe displayed within the Drum Grid - even if there is no MIDI data containedwithin the active drum track.
note02.gif Note: Drum Sets can also be created by choosing the Drum Sets option under the Setup menu. The Drums Sets dialog box allows Drum Sets to be imported, exported and modified.
Transposing from Drum Set to Drum Set
Transposing from Drum Name to Drum Name
Selecting All Note Data Across a Single Drum Name
Showing All Drum Names within a Drum Set
Rearranging the Order of Displayed Drum Names
Adding a New Drum
Nudging the Start Time of Drum Strikes
Muting and Soloing Drum Names
Scaling Velocities of Selected Drum Strikes
Changing Drum Strike Velocity Ranges
