Scaling Velocities of Selected Drum Strikes
You can scale the velocity of selected Drum Strikes by choosing the Velocity Tool (located at the top portion of the Graphic Editor). Make a selection withinthe Drum Grid display and choose the Velocity Tool; click and hold the mouse on any Drum Strike within the current selection anddrag the mouse higher or lower to scale Note On velocities. Notice the DrumStrike icons change according to their new velocity settings; releasing the mousescales velocity changes across all Drum Strikes within the selection. Sincethe Velocity Tool scales Note On velocities according to their original values, therelationship between individual note velocities within a selection will be preserved. The Velocity Tool can be thought of as a method to alter the overall dynamic of a particularselection.
Creating and Naming a New Drum Set
Transposing from Drum Set to Drum Set
Transposing from Drum Name to Drum Name
Selecting All Note Data Across a Single Drum Name
Showing All Drum Names within a Drum Set
Rearranging the Order of Displayed Drum Names
Adding a New Drum
Nudging the Start Time of Drum Strikes
Muting and Soloing Drum Names
Changing Drum Strike Velocity Ranges
