Changing Drum Strike Velocity Ranges
Six graphical Drum Strike icons distinguish between six user-definable rangesof Note On velocities in the Drum Grid display. Use the Drum Strike VelocityRanges display in the top portion of the Graphic Editor window to view or editthe range of any of the six Drum Strike icons.
To edit Drum Strike Velocity Ranges:
  1. Within the Drums display, select the desired Drum Set from the Drum Set pop-up menu.
  2. Click on one of the 6 Drum Strike icons displayed in the top portion of theGraphic Editor window.
  3. Click on the numerical range for the selected Drum Strike icon and enter in anew value designating the starting point for the Drum Strike’s Velocity Range; press the Return key.
Below are the default Velocity Range values for each of Metro’s six Drum Strike icons:
122-127
100-121
78-99
56-77
34-55
0-33
Creating and Naming a New Drum Set
Transposing from Drum Set to Drum Set
Transposing from Drum Name to Drum Name
Selecting All Note Data Across a Single Drum Name
Showing All Drum Names within a Drum Set
Rearranging the Order of Displayed Drum Names
Adding a New Drum
Nudging the Start Time of Drum Strikes
Muting and Soloing Drum Names
Scaling Velocities of Selected Drum Strikes
