Archiving Tracks
When a track is muted, Metro processes the track while playback is in
progress so that you can un-mute the track without stopping playback.
If you have lots of muted tracks, this can place a heavy load on your
computer. Archived tracks, on the other hand, don't place any load on
your computer. Therefore, if there are tracks you want to keep but
don't need to play, you should archive them instead. To archive a track: - In the track view, select the track or tracks to archive.
- Choose the Edit-Track Operation-Archive menu item.
The archived track name will appear in italicized text. See below for example. To unarchive a track: - Click on the track you wish to unarchive
- Choose the Edit-Track Operation-unarchive menu item.
See Also:The Tracks Window The Graphic Editor Window Playback Options in the Track Window |
