Drawing Aux Fader Movements in the Graphic Editor Window
You can also draw aux fader movements in the Graphic Editor window with thePencil tool:
  1. To display the data, click the data display popup of an audio track and chooseSend Vol.
The data display popup changes to read 'Send Vol: Aux 1.'
  1. Click the words 'Aux 1' to select whatever aux bus you want to display.
  2. Use the Pencil Tool to draw a fader curve.
  3. Make sure the Play button in the Instruments Mixer window is enabled and play back your track.
The next step in the effects tutorial is Applying Effects Offline.
