Edit Notes in Selection OnlyWith Edit Notes in Selection Only checked, Metro considers notes to be selected only if their start time lieswithin the current selection. In this mode you must select the beginnings ofnotes to edit them. This is usually desirable for Cut/Paste types of operations. When Edit Notes in Selection Only is not checked, Metro edits are truly WYSIWYG. If you Cut the end of a note whose duration extends into the selection,Metro will cut the end of the note off and place that portion of the note on theClipboard. This can be useful for clearing notes that unintentionally extendinto a measure they’re not supposed to. In another example, cutting in the middle of a long notewould produce two notes with silence in between. See Also:Editing Notes in the Graphic Editor Window Selecting Notes Defined by Particular Criteria (Selection Filter) Selecting Notes, Tracks and Sections for Editing |
