| Selecting Notes, Tracks and Sections for EditingTo use any of Metro’s edit operations, you first need to select the data you want to edit.Depending on the type of data you want to edit and the operation you’ll be performing, you’ll select data in different windows and use different methods of selection.For example, if you want to transpose a range of notes, you must first dragacross that range in the Graphic Editor window to select it. If you want totranspose all notes in all tracks in a Section, you first click on that Section in the Sections window to select theSection. Each window also offers Select Tools, for example, the Arrow Tool in the Graphic Editor window allows you to graphically select all notes (andother events including audio) across a specific time interval.Once you feel comfortable selecting data, experiment with various editoperations. For example, try using various commands in the Edit menu or Options menu—you can find explanations for all menu items in Metro Menu Commands.Metro provides a wide variety of selection options, including:Selecting Data in the Graphic Editor Window Edit Notes in Selection Only Option Choosing a Zoom Level in the Graphic Editor Window Selecting Noncontiguous Notes or Areas in the Graphic Editor Window Selecting Notes Defined by Particular Criteria (Selection Filter) Editing Notes in the Graphic Editor Window Repeatedly Pasting Notes Selecting Tracks or Track Regions in the Tracks Window Overview Types of Data Display in the Tracks Window Overview Selecting Sections |
