Edit Notes in Selection Only OptionIf the Edit Notes in Selection Only option in the Switches menu is checked (enabled), only the notes whose attacks (left-most edge of thenote icon) are selected will be affected by the edit operation. If this option isnot checked, only the part of a note that lies within the current selectionwill be affected. Since this is a WYSIWYG (What You See Is What You Get)operation, you may be left with fragments of notes after performing an edit operation,which is often undesirable. Be sure you set this option to the edit method youprefer. See Also:Selecting Notes Defined by Particular Criteria (Selection Filter) Selecting Data in the Graphic Editor Window |
