Selecting Noncontiguous Notes or Areas in the Graphic Editor WindowIf you want to select notes or areas that aren’t next to each other in time, Command-clicking and Command-dragging enable youto do so.To select noncontiguous notes:- In the Graphic Editor window, Command-click the notes you want to select.
Notice that the notes change color as you select them.To select noncontiguous areas:- In the Graphic Editor window, Command-drag the areas you want to select.
Notice that the notes in selected areas change color as you select more areas. See Also:The Graphic Editor Window Editing Notes in the Graphic Editor Window Selecting Notes Defined by Particular Criteria (Selection Filter) |
