Repeatedly Pasting NotesMetro’s Paste And command lets you repeatedly paste the same range of notes or Drum Strikes forany number of times that you specify To repeatedly paste notes:
Select a range of notes using either the Arrow Tool or the Forceps Tool.
Choose Copy from the Edit menu.
Click an insert point in the Graphic Editor window’s display area where you want the Paste to begin.
Choose Paste And from the Edit menu, and enter the number of times you want topaste the clipboard contents (copied range).
