The Pitch Bend DisplayTyping the p key, or choosing Pitch Bend from the Data Type pop-up menu within the current track’s titlebar, changes the current track to show Pitch Bend. The Pitch Bend range of the window is controlled (in semi-tones) using the Set Pitch Bend Sensitivity in the Pitch Bend dialog under the Options menu (the Define Outputs dialog within the Instruments Mixer window also provides Output specific Pitch Bend Sensitivity). Entering a greater value will increase the range of the display field and vice versa (the default setting is 2 semi-tones in both directions - 48 is the highest value). Use the Pencil and Curve Tools to draw and edit Pitch Bend, or use the Arrow Tool for selecting data. Hint: Selected Pitch Bend data can be modified using the Pitch Bend dialog within the Options menu. Hint: Be sure to use the Current Cursor Display (in the upper-left corner above theTime Line) as a reference when inserting new data using the Pencil or Curve Tools. |
