Curve Tools The Curve Tools, available in any of the Graphic Editor window's 'continuous data' modes, function much like the Pencil ToolContinuous Data. The Curve Tools allow you to draw smooth transitions of continuous data into the Controller,Tempo, Pitch Bend, After Touch, Poly After Touch, and Average Velocitydisplays. Just select one of the Curve Tools and click and drag the mouse in a track's 'continuous data' display area to create a smooth curve of data. Audio Track Volume Automation Metro's Audio Track volume automation employs special 15 bit controller data (32, 767 steps) to modulate volume messages encoded into an Audio Track. Use Controller 7 to create and edit Volume automation. Use Controller 10 for Panning automation, which is limited to 128 steps. Zooming in allows sample accurate placement of Audio Track Controller data within a track. Audio Track volume automation edited in the Continuous Data dialog is denotedas Controller number 7 with values between 0 and 127. Manually entered audiovolume controller values in the Graphic Editor window are interpolated to achieve15 bit resolution. See Also:Working with Audio Tracks and Audio Regions |
