Arrow ToolClicking the Arrow Tool allows the cursor to select all data limited in time. Just drag across thearea you want to select and all data (regardless of pitch) in that range will beselected. Command-clicking and dragging the mouse allows for noncontiguous selections acrosstime.You can also edit notes or Drum Strikes by Control-clicking or double-clicking on them when using the Arrow Tool; a Note Event Edit dialog box will open in which you can set specific parameters for that event. See Also: Pencil Tool Selecting data in the Graphic Editor window |
