| Placing Events at Precise LocationsYou can either specify an insert location before inserting the event or placethe event after you insert it. To specify an insert location before inserting the event: Metro SE users: - Set the insert location by clicking the correct time in the graphic editor before opening the event editor window.
Metro / Metro LX users: - Choose Set Selection from the Edit menu (or use Command-=). Then, set the desired location in the dialog box, and click OK.
Or, you can insert the desired event and then adjust its start time to movethe event where you want it. Selecting an event in the Event Editor implicitly selects a time range. Eventsare inserted at the beginning of the current selection. Therefore, if youselect one event and you insert a new event of any type, the new event will beplaced at that same time location. For example, if you select a note event at Bar3, Beat 5, Clock 245 and insert a Poly After Touch event, the Poly After Touchevent will be placed at Bar 3, Beat 5, Clock 245. You must then edit theBar/Beat/Clock start time of the new event to place that event where you want it. Hint: If you want to insert an event near or next to an existing event, be sure to select the existing event; then insert the event you want and adjust its start time accordingly. See Also:Event Information ChangingTracks Selecting Events in the Event Editor Window Selecting Multiple Events in the Event Editor Window Setting Event Start Time in the Event Editor Window Go To a Specific Bar in the Event Editor Window Selecting and Editing Event Parameters Inserting Events Filtering Event Display |
