Setting Event Start Time in the Event Editor Window
You set event start times using the
Bar/Beat/Clock
or
SMPTE Time
column in the left of the window. Choose
Bar Display
or
SMPTE Display
from the
Switches
menu to switch between time format displays.
Just click directly on the value you want to change; then move the mouse up ordown to raise or lower the value. You can also type the correct value directlyinto the highlighted field.
Event Information
ChangingTracks
Selecting Events in the Event Editor Window
Selecting Multiple Events in the Event Editor Window
Go To a Specific Bar in the Event Editor Window
Selecting and Editing Event Parameters
Inserting Events
Placing Events at Precise Locations
Filtering Event Display
