Remove Groove
Remove Groove
allows you to permanently delete any of the existing Metro grooves. To deletea Metro groove, simply select the groove from under the Remove Groove submenu under Groove Quantize (in the Setup menu) and it will be deleted. Remove Groove is useful for trimming down the physical size of the Metro application -especially if you need to take it with you on floppy diskette.
Paste Groove
Quantize
Quantize To
Playback Quantize
Remove Groove
