| Playback QuantizeThis column in the Tracks window (see Note, below) allows you to select avalue for the playback quantization of a track, which non-destructively shifts MIDInotes in the track to the nearest beat boundary on the fly during playback. Itdoes not alter the data on the track, merely affects how it is output duringplayback.To select the quantize value (from a whole note to a sixty-fourth note) thatyou want for each of the divisions of the quantization grid, click in thiscolumn and select a note value from the pop-up menu. Note: You can toggle on/off the display of the Bank, Pgm, Quantize, Transpose andVelocity fields in the Tracks window by using the display options pop-up menu.This pop-up menu is located above the track number column in the Tracks window. |
