QuantizeYou can quantize notes either:on input or after they are recorded and selected. Quantization shifts individual notes within a selected region to the nearestbeat boundary (eighth notes, sixteenth notes, etc.) that you specify. You canspecify a quantize value that places notes exactly on the beat or, if youprefer, closer to the beat by a specified percentage. Many people use quantizationto tighten up loose playing; after recording you can go back to a track andspecify where in relation to the beat boundaries you want your notes to fall. Metro’s Groove Quantize feature allows for the quantization of a track to the timingof a predetermined groove.To quantize data:- In the Graphic Editor or Tracks Overview, select the data you want to quantize.
- From the Options menu, choose Quantize.
The Quantize dialog box appears.- Choose the options you want (see list below).
- Click OK.
Quantization options:Attacks and/or Releases Quantize to Recognize triplets Groove named Track Groove Velocity and/or Duration Strength Swing See Also:Groove Quantize Playback Quantize Quantize To |
