Playing From a Selection or Bar NumberYou can begin playback at any particular section of your file by eitherselecting an insertion point in the Graphic Editor window, or by changing the Barnumber field of the Counter in the Transport window.To play back from a selection or bar number:Do one of the following:- Click the Arrow Tool in the Graphic Editor window then click in the GraphicEditor’s piano roll (when in Notes display) at the point where you want playback to begin. Thiscreates an insertion point.
- Click the Bar field in the Transport window and change it to the locationwhere you want playback to begin.
- Click Play or press the Spacebar to continue playback from the selectedlocation.
 Now that you have a track of note data, let’s try Adjusting Note Velocity. |
