| Hint: You can also use the numeric keypad to navigate to any measure in the active Section. As long as METRO is not playing, press the '.' (period key) on the Macintosh numeric keypad; then enter the measure number that you want to go to, or play from; press the Enter key and the Counter will set to the entered measure. Pressing the Enter key a second time will start playback from the specified point. |
