Recording Another Track
Let's record another MIDI track to accompany the first track you recorded:
  1. Click the Record 'R' column of the track you want to record, placing a selector dot in that column.
Option-click the track Name field and type a name. When finished typing,press Return in order to exit from Track Name mode.
Click Record (Transport window), or press Option-R, and play your MIDI device.
The previously recorded track plays back as you record; if you'd rather mute the track and only listen to the one you're recording, click the 'M' (Mute) column next to the previously recorded track's name, placing a selector dot there. To unmute a track, click the dot again to remove it.
Click Stop or press Spacebar when you're finished recording.
Repeat steps 1-4 to record more tracks. You can record up to 99 tracks perSection.
Don't worry if you aren't completely satisfied with everything you record. See Selecting Notes, Tracks and Sections for Editing to learn basic select and edit techniques.
The next step in our tutorial is Displaying Multiple Tracks in the Graphic Editor Window.
