| Digital Audio Dialog Options: LaunchCheck the Launch checkbox if you want Metro’s start-up to trigger DECK II’s start-up. When Launch is enabled, Metro will automatically find and open DECK II upon start-up (aslong as DECK II is installed on any mounted drive). However, if you have lessthan 12MB of RAM installed in your machine, there may not be enough memory toopen DECK II and Metro at the same time. Launch should be enabled in order for Open documents to function without first having to open DECK II.After launching Metro, you can temporarily bypass the DECK Connections settings by holding down the Option key for the entire duration of Metro’s start-up sequence; Metro will load without launching DECK II. |
