Controller Events
Controller events display the controller number and value after the Channel field. The Controller Number determines the type of that particularcontroller; for example, Controller 7 is Volume. The Controller Value determines thevalue for that particular Controller Type. Controller Numbers and Values both rangefrom 0-127.
Some commonly used controllers are:
Controller 1 Modulation
Controller 7 Volume (MIDI and audio)
Controller 10 Pan (MIDI and audio)
Controller 64 Sustain pedal
Controller numbers 64-69, 78, and 79 are switch controls; values of 64 or greater for these controllers are interpreted as 'on' and values of 63 or less are interpreted as 'off.'
Controller numbers 121-127 are reserved for channel mode messages, includingLocal Control, Omni Mode, Mono Mode, and so on.
Controller 0 usually precedes a Bank Select message.
Note events
Poly After Touch events
Programs events
After Touch events (Channel pressure)
Pitch Bend events
System Exclusive events
Bank Select
Controller Events
