Note EventsNote events display the note’s Pitch, Attack and Release Velocities, and Duration. You can change the pitch by clicking the Pitch value and editing it, or selecting the value and playing a note on your MIDIController. Velocities can range from 0-127. Duration is only displayed in Clocks or Bits (SubFrames). When viewing in the Bars Display, clocks are directly related to the current Clocks per Quarter Note setting configured within the MIDI Setup command under the Setup menu.See Also:Poly After Touch eventsControllers eventsPrograms eventsAfter Touch events (Channel pressure)Pitch Bend eventsSystem Exclusive eventsBank Select
