SysEx You can insert System Exclusive data using the Event Editor's Insert pop-up menu, or by using the File menu's Insert SysEx command (good for importing Text or Bin-Hex files containing SysEx data), oryou can record SysEx data directly into Metro from your MIDI device.No matter which method you use, the System Exclusive event will be displayedas text data in the Event Editor window and graphically as a vertical bar in theGraphic Editor window (the latter is true only if Show SysEx in Graphic Editor is selected under the Switches menu). You can edit System Exclusive data using the System Exclusive Event Editdialog box, which you can open from either the Event Editor window or the GraphicEditor window.In the Event Editor, click the word 'SysEx' in the Channel column to open the System Exclusive Event Edit dialog box. Then, using theHexadecimal number system, enter values to alter the event.Double-clicking in the left-most column in the Event Editor window opens theGraphic Editor window to display the graphic representation of the SysEx event. You can also open the System Exclusive Event Edit dialog box from the GraphicEditor window by clicking on the vertical SysEx bar. See Also:Note events Poly After Touch events Controllers events Programs events After Touch events (Channel pressure) Pitch Bend events Bank Select |
