Bank SelectBank Select messages can be inserted at any location within a track (BankSelect messages are dependent on a track’s port and channel assignment). The Bank Select message currently displayed inthe Graphic Editor window’s Bank pop-up determines which message will be inserted when using the Event Editor’s Insert menu. After choosing Bank Select from the Insert pop-up, the Bank Select message’s corresponding MIDI events are inserted at the track’s current selection or insertion point.See Also:Note eventsPoly After Touch eventsControllers eventsPrograms eventsAfter Touch events (Channel pressure)Pitch Bend eventsSystem Exclusive events
