| The Sections Window  The Sections window displays the Sections. Sections are either parts of songs, called subsections or complete songs. The maximum number of sections is 25000 for Metro and 8 for Metro SE. Note: Prior to Metro 6.0.5 the maximum number of sections was 32. From the Sections window, you can change the order of sections and create SubSections within other sections. The Sections window also has Song Playlist capabilities, allowing Sections toplayback one after another in chronological order. Sections can playback inorder and without interruption, or a preprogrammed pause can be set to playbetween Section transitions. Command-clicking the title bar of the Sections window of an existing Metro Document will reveal the path of that document. See Also: Working in the Sections window Naming a section Song Playlist Section Timing Options |
