Song Playlist
You can playback Sections in chronological order. In its default state, the Sections window plays the current Section without continuing on to the next Section afterreaching the end of the current Section. You can use Auto-Play mode to playsuccessive sections or Auto-Advance to play successive sections with pauses which youcan configure.
Auto-Play mode plays the active Section to the end, and then continues on toplay the entire duration of all successive Sections in chronological order,without a pause between Section transitions. Empty Sections do not play back aspart of Song Playlists.
Auto-Advance mode plays the active Section to the end, pauses, and thenselects the next successive Section in chronological order, adding auser-configurable pause between the transition of each Section. Empty Sections do not playbackas part of Song Playlists. Set the pause length in the Section Timing Options dialog.
Working in the Sections Window
Song Playlist
