Working in the Sections Window
You can name Sections by option-clicking (double-clicking is necessary for versions prior to 6.2) the Section name and typing a new name in the corresponding field. Drag a Section by its number to rearrange its order within the Sections window.
You can select Sections for editing by clicking the Section Number or Name.All the tracks in a selected Section will be displayed in the Tracks window, justas all the note and event data in a selected Track will be displayed in theGraphic Editor and Event Editor windows.
Initially Sections are titled 'Empty'; once a Section has been selected for any purpose, its title changes to 'Untitled' and a Selector Triangle appears to the left of the name. Section duration is displayed to the right of the name in minutes and seconds. Click on the Each label above the Section Times to toggle the time display between current timeand remaining time, or to turn off the Section Time display.
You use the Selector Triangle to drag Sections to tracks in the Graphic Editorwindow in order to create arrangements of up to 64 SubSections per track.
The Sections Window
Naming a section
Creating a Section
Selecting Events in the Section Event Editor Window
