Insert TimeInsert Time inserts time in a track or across multiple tracks. You define the amount oftime to be inserted by first selecting the desired length in time in theGraphic Editor window or Tracks window Overview. For example, drag across 2 bars inthe Graphic Editor window (in any display mode). Then choose Insert Time. The length of the selection will be inserted at the beginning of yourselected region. For example, your track will contain 2 empty bars that extend fromthe beginning to the end of the region you selected in the Graphic Editorwindow.  See Also:Delete Time |
