Delete TimeDelete Time functions similarly to the Cut command; however, Delete Time deletes both audio and MIDI data within the selected area and shortens thetrack by the length of the selected area. For example, if you select 2 bars in a10 bar track and choose Delete Time, the 2 bar gap will close and the track will shorten to 8 bars. To delete time from one or more tracks:- Select the area you want to delete in either:
- From the Edit menu, choose Delete Time.
All selected events plus the time represented by the selected region areremoved. See Also:Delete Tracks Clear Insert Time |
