CutCut removes selected audio and MIDI data from its original location and places iton the Clipboard. Using another edit operation, such as Paste or Merge Data, retrieves this data from the Clipboard. If you perform an edit operationthat does not retrieve this data, such as another Cut, this data will be deleted and lost. The result of only one edit operationat a time may be contained on the Clipboard. See Also:Copy Selecting Data in the Graphic Editor Window Undo |
