Clear Clear removes the selected audio and MIDI data from the window but does not place it on the Clipboard. The data you Clear can only be retrieved by Undo. When applied to tracks, Clear removes all data contained within selected tracks while leaving Track Namesand Output assignments intact.Clear removes all audio and MIDI data, but does not delete the track parameters like Output assignments and the Track Name. See Also:Cut Copy Delete Tracks |
