| Transcription Quantize amountWhen METRO transcribes MIDI data into standard musical notation, it uses theTranscription Quantize setting to select the smallest note value that you wantin the score. This allows the notation to compensate for sloppy playing.METRO’s smallest transcription quantize amount is the triplet value of the selectednote value. For example, if you select a sixteenth note as the TranscriptionQuantize value, the smallest note value that METRO recognizes and transcribes isa sixteenth note triplet.To set this value, choose a transcription quantize amount from the palette. METRO automatically recalculates the score using the new value. |
