Drum Machine Style Recording
Drum Grid editing coupled with drum machine-style recording comprise an excellent tool set for recording and editing rhythmic loops in Metro. Real-time MIDI editing keeps the creative juices flowing, allowing you to edit without having to stop the recording process.
The Record and Play Setup dialog box configures Metro for a variety of record loop modes including Song Building mode, which is a great way to emulate drum machine-style recording.
In the previous tutorial you used this same dialog box for setting up a countoff time. Now let's configure Metro's record mode:
- Choose Record/Play from the Setup menu.
The Record and Play Setup dialog box appears.
- Click the Song building mode button to select your record mode setup.
- Enter 1 in the field for 'N' Tracks maximum when loop recording. This sets Metro to record each of its loop passes onto a single track.
- Click the Overdub button to select your Record mode setup. Selecting Overdubas the record mode instructs Metro to layer each record pass on top of oneanother.
- Click OK to enter your new settings and close the dialog box.
- Open the Transport window (Command-B) and expand its window to full size, ifnecessary.
- Click to select the Rec checkbox within the Looping display. This enablesrecord looping.
You've now configured loop recording in Song Building Mode, which overdubs successive record passes onto a single track. This is exactly the formulaneeded to emulate drum machine-style recording.
The next step in this tutorial is Creating a Section.
