Using the Notation Window
If there is MIDI data in the current sequence, the window opens with each MIDItrack transcribed as an individual staff. If there’s no MIDI data or only digital audio data, the window opens with a singleblank staff, representing the next available sequencer track. The score doesn’t display Digital Audio Tracks.
Each track in METRO appears as a
staff
. Groups of staves are called
systems
Adjusting staff spacing in a single system
Adjusting staff spacing of all systems in a score
Adjusting staff spacing of all systems on a page
Adding Measures to a Track
Using the Setup Notation Track Dialog Box
Opening the Setup Notation Track dialog box
Features of the Setup Notation Track dialog box
Adding or changing the track name
Adding or changing the abbreviated name:
Showing/hiding the name or abbreviation
Setting the staff display options
Changing the scale of the staff
Assigning an instrument to the staff
Selecting the clef for a staff
Selecting an instrument range
Defining a drum map for a percussion instrument
Showing/hiding a track
