Controlling Tempo
If a Section contains Tempo events, these events will control the currentplayback tempo. There are a number of ways you can control tempo in a Section; the method you use depends on how you like to work and if you want to placeone tempo event in a Section or multiple events over time.
Try any or all of the following ways to control tempo:
Entering Tempo Events in the Tempo Dialog Box
Entering and Editing Tempo Events in the Section Event Editor Window
Recording Tempo Events
Tap Tempo
Recording Tempo Changes from Your Controller
You can also draw tempo events in the Graphic Editor window. See The Tempo Display.
Controlling Tempo
