Recording Tempo Changes from Your ControllerOne of the most interesting ways to control tempo , volume, or many other parameters is to assign one of your controller’s sliders or wheels to control a particular parameter. To record tempo or parameter changes from your controller:- From the Setup menu choose Record Criteria.
The Record Criteria dialog box appears.- Make sure that Pitch Bend, Modulation Wheel, Controllers, and Tempo Changesare checked, and click OK.
- From the Windows menu choose Remote Control.
The Remote Control dialog box appears.- From the Insert popup menu choose Controller or Pitch Bend (depending on whichwheel you want to use on your controller).
- Click whatever term is in the Command column to open the popup menu; choose Tempo, Output Vol., or whatever parameter you want to control.
- Click the Ch. Column to choose the MIDI channel of the patch or Output you want to control.
- Record enable a track and press Option-R to start recording.
- Move the appropriate wheel or slider on your controller to send tempo orparameter data.
- Press the Spacebar to stop recording.
You can view your results in the Section Event Editor or Graphic Editorwindows. |
