Recording Tempo EventsYou can also record multiple tempo events over time using the Tempo setting in the Transport. The Section adjusts to these various tempos during playbackMetro scales the value of tempo events you record when using the Transport’s Tempo setting. To record tempo events:- Choose Record Criteria from the Setup menu.
- Check Tempo Changes if it’s not already checked, then click OK.
- Record enable a track by clicking in the Record column, placing a dot there.
- Click Record or press Option-R to begin recording.
- If you want to record a stream of Tempo events over time, drag the Temposlider in the Tempo setting left or right.
- If you want to record one Tempo event for every click-and-release of themouse, click the Left or Right Tempo arrows (each arrow click is the equivalent1/10th of a beat).
- Press the Spacebar.
Choose Section Event Editor from the Windows menu. Notice a stream of Tempoevents is contained in the Section Event Editor. Tempo events are saved withSections (not tracks), therefore, Tempo events are placed in the Section EventEditor. See Also:Entering and Editing Tempo Events in the Section Event Editor Window Entering Tempo Events in the Tempo Dialog Box |
