| JukeBox Preferences Pane Fast Scan files bypasses QuickTime to potentially speed up the scanning of folders but could also, when selected, miss some playable audio files. If you are using files from a PC you may want to uncheck this option. Automatically Size Columns causes the JukeBox to do its best to determine the best width for each column. Remember Last Folder will cause Metro to scan the last selected folder when it restarts. The Nominal Bit Rate specifies the quality of the Ogg Vorbis converter. The higher the bit rate the better the quality Back to preferences |
