Digital Audio Dialog Options: QuitCheck the Quit checkbox if you want quitting Metro to trigger quitting DECK II.Tolerate 'N' Errors Before Syncing enter the number of syncing errors DECK II should tolerate before syncing up Metro. Experiment with this option if you're experiencing problems syncing Metro to DECK II, or are running a slower CPU. Keep in mind that decreasing Metro's Clocks per quarter note setting (found in the MIDI Setup dialog under the Setup menu) may yield better results when connecting to DECK on slower CPUs. |
