Stereo Delay
The Stereo Delay is much like its simpler cousin, but it offers some interestingadditional capabilities and allows you to create a stereo effect out of a monoaudio signal (or use the left channel of a stereo track). By using separatesettings on the left and right channels of the effect, you can create interestingand expansive effects.
Delay L
Sets the length of delay for the processed left channel in milliseconds. Youcan use values from 0 to nearly 1000 ms (equivalent to 1 second).
Delay R
Sets the length of delay for the processed right channel in milliseconds. Usevalues from 0 to nearly 1000 ms (equivalent to 1 second). For an interestingeffect, set this to a different value than Delay L.
FBack L (Feedback L)
Controls the amount of left channel signal the delay will feed back into itsleft channel. As you increase this value, you will notice a more pronouncedecho, until the feedback actually becomes louder than the original sound. Settingthis too high can result in distortion. You can use values from 0 to nearly 100per cent.
FBack R (Feedback R)
This function works identically to the FBack L control, except it affects the processed right channel.
Volume L
Sets the volume of the left channel’s delay effect in decibels. Use values from 0 (full volume) to -8 (zerovolume).
Volume R
Sets the volume of the processed right channel.
Adding Effects in Real-time
Adding Offline Effects
Effects Tutorial
Stereo Delay
