Fade The Edit menu's Audio > Fade command allows you to choose how suddenly your audio clip fades out or fades in. You have three volume shapes to choose from: - Exponential 1
slopes steeply at high amplitudes and then flattens out - Exponential 2
slopes steeply at low amplitudes and then flattens out - Linear
straight-line slope You also select how much of an amplitude change you want by filling in apercentage in the number fields at the botom of the Fade dialog box. To fade in or out:- In the Graphic Editor or Tracks windows, select the part of an audio clip thatyou want to fade in or out.
- From the Edit menu, choose Audio > Fade.
The Fade dialog box appears.- Choose the volume shape you want to apply.
- In the From 'N'% to 'N'% fields, type the percentages by which you want the volume to change.
- Click OK.
Metro applies the volume shape and percentage change that you choose. See Also:Normalize Group Normalize Reverse Scale Amplitude Cross-Fade Split Stereo TracksCombine Regions |
