| Advanced MIDI RecordingAdvanced MIDI recording requires you to enable various settings for theoperation you want to perform. For example, in order to record Controller events youmust enable the recording of Controllers by checking that setting in theRecord Criteria dialog box (Setup menu). In order to enable recording in aparticular Loop Record mode, such as Multiple Take mode, you must check that setting inthe Record/Play dialog box (Setup menu). Remember to verify the appropriatesettings if recording does not occur as expected.Once you enable (or disable, as the case may be) a Metro setting, you mustsave that setting if you want it to remain in effect when you reopen Metro. Yousave settings by clicking the Save button in any of the Preferences dialog boxes (File menu). Clicking Save in any of the Preferences dialog boxes not only saves all settings listed in the dialog, but saves most other settings you may have chosen in Metroincluding Output Setups, Switches, the placement and size of Metros windows, Program Names, and more.Advanced MIDI recording techniques include:Tap Tempo Recording System Exclusive Events Punch Recording Loop Recording Song Building Mode Using Song Building Mode in Replace Using Song Building Mode in Overdub Recording in Multiple Take Mode Step Recording Step Recording from a MIDI Device Step Recording with the Pencil Tool |
