Digital Audio Dialog Options: Open DocumentsCheck the Open documents checkbox if you want Metro to automatically open the associated DECK IISession document when selecting Open under the File menu to load a previously saved Metro file. Uncheck Open documents to open and save Metro files without affecting the Session file currentlyloaded within DECK II.When Open documents is enabled, choosing Save or Save As from the File menu automatically links the current DECK II Session document with the savedMetro file. Important: Open documents also appears in DECK II’s Slave Settings Preferences dialog, but this setting should only be enabled within a single application. Therefore, only enable Open documents in either Metro or DECK II. You will run into errors when opening files if Open documents is enabled within both applications. |
